Well, this happened
Rich_M
And by the way, i never noticed anything until the bearing fell apart. Rode great for 800+ mi. Also, HMAN was correctly pointing out they had only installed 2 bearings on the wheel (they never installed the inner wheel bearing). I’m not the original owner, so I guess I’m cleaning up someone else’s mess. The community has been great. It’s really tough to find information on these older BDM’s any place but here. So thank you everyone!
Rich_M
Hey Bud. Yeah you are definitely missing a spacer as I have been pointing out all along. Look at these. They are off of my’04 Ridgeback. You can see that what you have there is a bearing race as HMAN pointed out. It is not the other spacer.The two spacers with the little lip go towards the bearings. Lip to the bearing. View attachment 141536View attachment 141537
Thanks for the pic! Definitely helps!
Mickmorris
Well Known Member
The two I have do have the little lip on them.
Post a picture of both of them. If they both have the little lip you’re missing the outer spacer for the brake side. Sure looked like the smaller inner spacer was missing but I couldn’t see the bushings clearly enough. Definitely the other you can throw in the trash can. It clearly doesn’t belong.
Mickmorris
Well Known Member
My understanding regarding the lip is this is mostly for a mild dust seal and easier alignment while assembling. Am I wrong on that?
I actually believe you could get away with using a matching size width bushing without the lip. I know I would if I was in your position and couldn’t find one. Mr. Wright might be able to make you one. He is pretty clever that way. Worth asking the question. I will post a picture in a bit with the exact measurement of that bushing.
Mickmorris
Well Known Member
Thank you Mick. You’ve been super helpful. Not too many ‘04 Ridgeback owners out there. We got to stick together!
I hope this helps you get what you’re needing to get back on the road. One pic is with the lip / the other with out. I would make your replacement match the measurement with the little lip. I realize it is just like a 1/16” bigger but I would go with that. I’m sure someone else would know for certain if that would be sufficient to keep you motoring. Good luck with it!
:chopper: :cheers:
JohnBoy
The lip is for the inner ring on the bearing which should not turn as it is on the axel. The only moving parts are the balls inside because the outer ring is in the hub. If you don't have the lip you side load the dust shield which side loads the balls inside and wears out the dust shield and the bearing. That is why you have a lip on both right and left side spacers.
