Well, this happened
Rich_M
Finally rode my bike without a helmet around the neighborhood, and ID’d what the scraping noise was (hint: it wasn’t my brake caliper). That’s the rear bearing with the ball bearings OUTSIDE the housing. Mo’ horsepower mo’ problems. LolIMG_8398.jpeg
Mickmorris
Well Known Member
Got the wheel off and ID’d the cause. Apparently they didn’t know about the center bearing, because there wasn’t one.
I’m confused. Center bearing-wasn’t one. Are you referring to the axle spacer in the center of the rim for the axle to slide through? Looking at your photo I can see that the brake side bearing ( which there is only one on that side) is completely destroyed and I don’t see the spacer that should be between the bearing and brake caliper mount anywhere…. I do see the spacer for the brake and frame so that is good. But there should be 2 of them. The drive side should have 2 bearings pressed into the rim. And a single spacer between the bearings & frame. Post some more pictures of what you got there.
He only had 2 bearings in the rear wheel. Someone left out number 3!
Rich_M
OK, every day is school day, I have all 3 spacers. I took the wheel to the shop and got new OEM bearings (all 3) pressed into the wheel. Now I am reassembling. I have a 2004 Ridgeback and I want make sure the spacer order is correct. Should have taken better pics. It’s LH belt drive. So does this order look correct? It axle would be sliding in from the right and the brake caliper goes between spacer with the groove and smaller flat spacer. I think the larger flat spacer goes on the left, but I’m not 100%. Just want to get some advice before I run it. Thanks!
Rich_M
Also, I am having a hell of a time getting these lined up. Is there a trick to these, it seems like it would fit if the chamfers fit in somewhere, I’m like less than 1/4” off here. Suggestions appreciated
Mickmorris
Well Known Member
Hey Bud. Yeah you are definitely missing a spacer as I have been pointing out all along. Look at these. They are off of my’04 Ridgeback. You can see that what you have there is a bearing race as HMAN pointed out. It is not the other spacer.The two spacers with the little lip go towards the bearings. Lip to the bearing. IMG_6285.jpegIMG_6287.jpeg
knothead
Either the spacer was not put back in or the wheel bearing walked out and chewed the spacer up...hard for me to beleive the bearing walked out and chewed the spacer without hearing some crazy shit going on not to mention the ass of the bike walking side to side in curves...blows my mind how it got to this point
