Well, this happened
Rich_M
Finally rode my bike without a helmet around the neighborhood, and ID’d what the scraping noise was (hint: it wasn’t my brake caliper). That’s the rear bearing with the ball bearings OUTSIDE the housing. Mo’ horsepower mo’ problems. LolIMG_8398.jpeg
Mickmorris
Well Known Member
Got the wheel off and ID’d the cause. Apparently they didn’t know about the center bearing, because there wasn’t one.
I’m confused. Center bearing-wasn’t one. Are you referring to the axle spacer in the center of the rim for the axle to slide through? Looking at your photo I can see that the brake side bearing ( which there is only one on that side) is completely destroyed and I don’t see the spacer that should be between the bearing and brake caliper mount anywhere…. I do see the spacer for the brake and frame so that is good. But there should be 2 of them. The drive side should have 2 bearings pressed into the rim. And a single spacer between the bearings & frame. Post some more pictures of what you got there.
He only had 2 bearings in the rear wheel. Someone left out number 3!
