Drive belt replacement hardtail.
Mickmorris
Well Known Member
I’ve been looking for a step by step on replacing the drive belt on a BDM Pitbull. With no luck. There is no description in the service manual. Anyone have a breakdown on it.
No you probably won’t find a step by step breakdown. But being you have a RSD bike it should be a heck of a lot easier than changing one on a LSD. May I ask why you are wanting to change your belt?
Mickmorris
Well Known Member
Something pushed up through the belt. View attachment 141395
Well that sucks! So to start you will need to have the bike on a scissor lift of some sort. Remove the axle covers. Then take some pics of the bushings locations before disassembly on both sides so you get them back in the right spot. Should be 2 on the brake side and one on the drive pulley side. They go back on in a specific way so make sure you mark which side goes towards the bearings. Should be a small lip on that side. Then take pictures of your axle adjustment bolts so when you put it all back together you can put the adjuster’s back on the exact thread count it was at previously for your current belt adjustment. Theres a small hole in the joint at the frame to access the axle adjustment bolts. There’s a hex head plug & THEN the axle adjustment bolt. (At least there should be a plug first). The axle should have a retaining bolt on one end. 3/4” I think. Remove it then lower the bike until the wheel lightly touches and you should be able to pull the axle out. You may need to put something like a small wooden dowel in the end the retainer was in and tap it lightly with a rubber mallet to get it to go. Just be careful not to damage any threads where the retainer goes in. Getting those big wheels off with the brake assembly can be tricky. Just take your time and try not to scratch anything. Hope this helps you get going.
:chopper: :patriot:
Grape
:chopper: :patriot:
I got the drive belt installed. So a big thank you to Mickmorris for the breakdown. I have one thing to add. Remove the brake caliper when you start removing the rear wheel and reinstall when you have the rear wheel replaced. It does get in the way.
Mickmorris
Well Known Member
Glad you got it swapped out. For your final adjustment you should have just a small amount of movement on the belt if you push up on the bottom part midway between the front & back pulleys. Very minimal. Make sure both adjusters are moved exactly the same amount if you need to tighten or loosen it to get that little bit of play in the belt. Just imagine the difference in swapping the belt on LSD. The entire primary has to come off.
:chopper: :cheers:
Grape
:chopper: :cheers:
The LSD is a real pain. I measured it all out and used the belt tension tool to get the belt at 1/4 to 1/2 inch at 10 lbs. Again thanks for the help.
