Need advice on engine stalling reasons
SKOGDOG
One of the old ones.
My long winded point is when in doubt call Knothead. Thanks to everyone on here that shares your knowledge and advice. It really has made a significant difference for many people over the years.
haha. Snuffy is spot on…… My transmission started leaking oil into the primary—-end play on the input shaft compromised the seal. Happily I had another transmission ready to go, and spent several days disassembling the whole bike to install the trans. Before I was done I had asked advice or borrowed tools from: Mastiff Dave, Blacktopper, Th3Infamous1 (Eric), Knothead (Tracey) and Mr. Wright (Shannon). And of course Donna at HDM and Matt at Baker (very helpful guy there). In addition, I wore out several attachmets on my neighbor’s Dremel grinding on a clutch spring and my primary (bigger rotor), so I’ll replace those too.
I made sure to spread around the phone call questions so no single individual would realize how dumb I am……clever, eh? In reality, each of those guys bent over backwards to help—-Shannon was particularly indulgent. Blacktopper gave me a 3’ torque wrench that made short work of a 160 ft lb crankshaft hub nut, and Dave lent me an impact wrench that I think maybe sprained my wrist! Did you know that the big nut on the output trans shaft is 1 7/8” and is a lefthand thread and costs $32? I found that out because I thought it was rt hand thread, paid $25 for the big ass socket and used Mastif Dave’s impact wrench which promptly peeled all threads from that nut-haha.You learn all kinds a stuff. Big Dog guys are the best!!
Truly, without the Big Dog community, it would not go so well—finished the job this afternoon and now impatiently waiting the 24 hrs curing time for the stator plug Permatex.
Just in time. Headed to Galveston with Blacktopper soon to the Lone Star Rally. Stay tuned.
HiTech
Paying closer attention to RPMs when the engine dies, I noticed it's around 3000 rpm & maybe a bit higher. Engine can sustain good operation at 3000 IF I feather the throttle up to that point but a quick twist & a spike to 3000+ risks engine dying. Meantime I ordered the official master jet kit from S&S, not the lower cost clone kits that are often metric threads & don't seat well.
Mikeinjersey
Your current descriptions of your symptoms would lead me to concentrate on your accelerator pump circuit. Make sure your ejector nozzle is not clogged or the pump itself is not working well. Look down the venturi while hitting the throttle and you should see a healthy squirt. Make sure the blue ejector nozzle O-ring is in place.
If you are vented, clean and jetted properly your problems will be over. If you haven't had a chance to look at this link to Lowbrow Customs take the time and I think you will find it very informative.
SKOGDOG
How did your repair turn out skogdog
All good. I replaced the clutch pack—and after 100+ miles, the transmission’s good—no leaks and shifts like a dream….I still had a little slippage when I punched it in 3rd or 4th at 3000+ rpm and strongly suspect the disc spring. Otherwise the clutch held just fine. After a discussion with Josh @Gateway in STL, I ordered a silver (intermedia tension) replacement disc from Rivera Primo. Tomorrow I’ll remove the pivot plate and Dremel off the feet to accommodate the new spring. My old disc was (2008 w/75,000 mi), so I can forgive it being a bit tired—haha. My engine has a 585 cam and I always thought there wasn’t quite enough clutch for it. I’m confident the issue is resolved. The old trans worked perfectly but had end play in the shaft and leaked oil into the primary. Pretty sure Jason at Gateway can replace the bearings and seals in my old transmission so I’ll still have a spare.
Again—please forgive the interruption of the onging carburetor discussion.
May be the tank's gas cap vent is slowly closing down. Maybe break the cap loose (tape the cap so it does not fall off) and ride it. See if there is a change in throttle opening. Throwing spitballs here, see who sticks.
