rip kit gen 1 install
hey friends ted here, i have a wiring question on a gen 1 rip install. my 05 big dog mastiff 117 s/s
always had issues with the old wires plus kit. decided to do an upgrade. im almost finished with the install.
however i decided to swap out the red lead block and 40 amp fuse with a 40 amp breaker box.
my question is i have 3 sets of wires to my breaker box my voltage regulator, my double red wires from the rip harness with
o ring and my jumper lead to battery. which wires go on which post.
the gold post battery and the silver post aux. any help would be greatly appreciated
Mickmorris
Well Known Member
I guess I’m not following you clearly. Your VR should hook to your breaker and battery directly. Your EHC shouldn’t be connected to the breaker itself it should be connected directly to the battery with a separate 20/30A fuse inline between the battery and the EHC. In my opinion.
Mickmorris
Well Known Member
You can see in this photo the braided red at the top is the hot from the 40a fuse/VR. The middle line on the terminal is the hot to the starter. The lower right is the hot from the EHC and you can see the 20a inline fuse just below the connection. When it’s all said and done you should have a 40a on the VR and a 20a on the EHC connections to the battery. The bottom photo shows my VR connection and the 40a fuse available from bigdogpartskingpin. IMG_5548.jpegIMG_5549.jpeg
