Primary cover leaking
Gottaflirt
Leaving it all behind
I have a 2007 K9 and I have tried to seal the primary cover 4 or 5 times doing it the way the manual instructs and any other way I can think of.
A few years ago I saw in a magazine in it was an advertisement for a improved rubber seal, The difference I noticed in the improved seal was instead of being square shape it was round snd had ribs running the long way. The ribs looked as if they insreraased the amount of sealing service and I wouldn't be surprised iif was a slightly larger diameter. If any one knows a vendor that can get one give a shout.
Whlie the cover is off, take a fine flat file and go over both mating surfaces lightly. Ive had 2 covers that had a lip on the mating surface. Until filing it down, it would never seal. Good luck with the gasket.
Snuffy
Make sure its the seal. Papa Stein had the same issue, so he thought, it turns out the vent was spewing a little and looked like the primary was leaking. Good luck
Gottaflirt
I did try the file it didn't seem to help. I also put a layer of black permatex under and over their rubber band. Still no seal poor design. I have no problem with my 2004 with its paper gasket.
bikeone
oil leaks from primary cover, inspection cover or drain plug seat?
purchased some years ago primary gasket and inspection cover gasket (sqare profile) at big dog is back (Matts shop).
Maybe bigdogpartskingpin sells them too.
Check your primary on a glass table for flatness.
If it isnt flat bring some sandpaper with doubleside adhesive tape on flat base and grind it till the cover is flat.
if it is o.k. start fixing at the middle screws.
mleach72
I know this has been well covered, but maybe not everyone has heard. How much fluid are you running in the primary? The recommended 32 oz is too much in the 05-11 primary. It causes pressure problems that result in primary leaks. Most run 18-20 oz and it stops the leaks. I fought primary leaks for years. I finally got tired of it and had an open primary installed. Later on, after joining this forum, I learned that a quart is too much fluid, and was probably the cause of my leaks.
troyforge64
Those flat gaskets seem really picky once the cover has been off a few times. A ribbed seal sounds like it would forgive a little surface mismatch better.
windytailpipe44
Those flat gaskets seem really picky once the cover has been off a few times. A ribbed seal sounds like it would forgive a little surface mismatch better. Funny how that works, even a Uspin Casino https://uspin-casino.fr slot usually behaves better when the parts underneath have a bit more tolerance instead of needing everything absolutely perfect.
Yeah, the flat ones seem to lose their patience fast if the cover isn't perfectly true. A little ribbed profile would make way more sense here.
Gottaflirt
I agree 32oz. of primary oil is too much. I cut it back in both my bikes a few years ago and installed the improved
vent sold by Big Dog Parts Kingpin. From all of the feedback I have gotten on this subject I'm going try placing the cover
on a pane of glass to find any uneven spots. We'll see . . .
Gottaflirt
I am going to try the glass table idea. Let you know if it shows any imperfections. Thanks!
