Rear Wheel
knothead
You have 3 wheel spacers...the large wheel spacer goes on the pulley side with the lip facing the bearing and the other end of it against the swingarm.
The other 2 spacers goes on the opposite side...the spacer with the lip goes toward the bearing...the other spacer that has no lips at all goes between the caliper bracket and the swingarm.
Sometimes even with the spacers in the there will be a little slack and that because the swingarm is sprung...once you put the axle in and tighten it up the free play is gone...rear axle torque is 65 ft lbs
