Need to go!!
Steven Proctor
Yes sir. I took a look at my set up and when I measured it is 12 3/8, 12 1/2. If your still interested
Yes sir it looks almost the exact same. Almost.. If you'd like it just let me know and we will get everything situated and worked out. Thank You sir.. ps, Nice Bike
Unfortunately, the only item I would really want is the belt, but since it is 4" wide, it won't fit my setup. I don't think it would be safe to cut it for a more narrow fit. LOL. I appriciate it though. Hopefully you can get it sold, even if you have to part it out.
KShep85
I’m thinking tooth count? I know my BDL belt is way different from the karata belt. It’s the tooth count that matters though. Not so much length….
Yes i measured it twice by tooth count and got 138 both times. Here's a couple pics of the numbers off the belt if it will help..
KShep85
That! Length too—and even angle of the teeth. But it sure looked like the 4” Karata I had—o can look up the belt #’s from the photo I’d think.
How are you sir. So the full circumference is 46in. From center to center on pullys is 12 3/8. 138 tooth count and 45° angle on teeth
Mickmorris
Well Known Member
Now that’s some good information for someone needing one of these belts that will most likely never be available again….clutch basket as well…I’m sure someone is going to take this off your hands..
:chopper: :cheers:
