My pup just turned off
Cadena
I was roaring down the road then the bike just shut off. Now, it won't start NOTHING. Battery is still charged. No power nowhere but the battery and to those studs fir that little fuse box. Where do I start?
Mikeinjersey
Not sure which bike you have but this guide may help you. Make sure the battery connections are clean and tight. If your battery shorted out internally you could get the failure you described. Voltage on the battery should be 12.8 vdc while not running.
If you have a fuse box (not a stock item) check the fuses.
Unsprung
In the Potters hand...
Had that happen to me, took the time to go through the bike and found a fuse holder that was loose and sloppy causing intermittent contact issues. I have a RIP 2 kit installed with fused power to the battery.
Off the top of my head, crank sensor? Bad key switch? Loose connection in the harness or EHC? Did you blow a headlight or did the connector melt? Did you trip the circut breaker? Throwing it out there for consideration.
Mikeinjersey
Do you get any lights on the EHC when you turn key on? Send a pic of your ehc and fuse box so we can see what you have. This WD may help you.
Pull the EHC and check that the pins are OK and replace the dielectric grease. Never hurts.
Check your headlamp bulb and connector for signs of shorts. Burnt or melted?
