Not sure which bike you have but this guide may help you. Make sure the battery connections are clean and tight. If your battery shorted out internally you could get the failure you described. Voltage on the battery should be 12.8 vdc while not running.I was roaring down the road then the bike just shut off. Now, it won't start NOTHING. Battery is still charged. No power nowhere but the battery and to those studs fir that little fuse box. Where do I start?
Mine did that when the EHC was going out. Would just cut off for no reason and nothing else. After a few it would start back up and be ok for a while. Then the other weird stuff started happening. No headlight and other stuff. Good luckChecked it All. I'm thinking now EHC
Do you get any lights on the EHC when you turn key on? Send a pic of your ehc and fuse box so we can see what you have. This WD may help you.I was roaring down the road then the bike just shut off. Now, it won't start NOTHING. Battery is still charged. No power nowhere but the battery and to those studs fir that little fuse box. Where do I start?
Headlight is goodMine did that when the EHC was going out. Would just cut off for no reason and nothing else. After a few it would start back up and be ok for a while. Then the other weird stuff started happening. No headlight and other stuff. Good luck
