knothead
Second Chance Customs
If you have trash in the bowl the needle will not seat and let it overflow...also could be a small burr or anything in the seat area that will cause it alsoThe rubber boot that the pump rod goes through is supposed to have a hole at the top right? It does. But the sides have cracks in the bellow (accordion type boot). Would that cause fuel to leak out of the overflow? The float is at 1/8" from the top of the bowl where the gasket rides. Lowered it a little and it still leaks but not a much.
