Wire Plus installation
knothead
Second Chance Customs
Mornin' - hoping someone might have a copy of the installation instructions (links don't work anymore) - somehow lost mine and am trying to chase down an electric gremlin - 06 K9 - thank in advance.
What is the issue you are having with the bike...several of us on here know quite a bit about the wire plus system
dingo
First 50
Hey Knot - hope all is well - I installed one of the first versions from Jake years ago - had bike on trickle charger - charger light was flashing red and had no power to anything - replaced battery as it was pretty old anyway then realized there is a black wire with a 15 amp blade fuse that keeps blowing when bike is keyed on - cannot for the life of me recall what a black wire with a 15 amp blade fuse would be for (possibly the scorpio alarm) but still no power to anything - will be putting the bike up on the lift and digging in deeper this weekend - was hoping to have the diagram by my side as a guide, if needed.
knothead
I will look to see if I still got the paper work on a wire plus
dingo
First 50
Just got a 2004 Ridgeback. Having trouble with the head light changing to low beam. Any ideas?
Adding to Knots feedback - generally, when the low beam is out, the headlight will default to high beam for safety reasons - so when you hit the switch to low beam, it automatically goes back to the working high beam. if this is the case - you need to change the bulb. Hope this helps!
Rottweiler
Big_Dog_2007_Wire_Plus_Diagram.jpgNot sure if this is what you are looking for but it is all I have for the wire plus.
If it is I can email you the file so you can blow it up.
Rottweiler
I will email you the picture. It might be the same as the download. That is how I got it years ago.
dingo
First 50
Update: Hey all - thanks again for your assistance - problem was the switch module - it smoked like many others have before - fortunately, I had a spare and am back up and running for now - have the RIP kit sitting on the shelf if I ever need it in the future - gotta keep the dog running !!
