clutch adjustment problem
knothead
Sounds like the clutch hub nut is backing off and causing you to loose the clutch adjust so fast...I would check it...red loctiteand 80 lbs of torque...some folks is going to say to do it 150 but I wouldnt do that because you got to remember that is a harden hollow shaft...I have changed transmissions for people because they torqued it to much...at max I wouldnt go no more than 110 foot lbs
