front forks problem
Mickmorris
Well Known Member
Hi, I'm Adam from Poland. How to disassemble the tubes from the lower forks element in this forks ? Is the tube screwed in or pushed in?
Looks like a hot leg. Does the axle thread directly into the right leg from the left? Either way it’s pushed in not threaded. Should be a locking clip under the dust cover on top of the seal. Post a couple more pictures of the entire fork. Top & bottom.
Rottweiler
How To service your forks
This is a really good post about the front forks.
banan
a good topic, but I have different forks :)
banan
I want to restore the chrome parts, so I have to completely disassemble them. The lower element has a notch secured with a screw.
Mickmorris
Well Known Member
So I can’t see the top of the lower super clear but it looks like the dust cover on top is 6side to allow for a wrench to get on it? That would indicate a treaded connection. I had thought maybe those were arlen ness hot legs but after seeing your picture I don’t believe they are. I don’t know if these pictures will help you in any way but can’t hurt to share them. If the cap on top of the lower appears to be threaded I would start there. Underneath should be a locking clip to hold the seal in. IMG_6195.jpegIMG_6208.jpegIMG_6209.jpegIMG_6260.jpegIMG_6279.jpegIMG_6285.jpeg
banan
thx but my forks is different
