If you figured out how easy it is to read a plug now, [seeing that plug chart]... Then, figure this shit out; it's too simple.OH MY GOD PLEASE GO AWAY!!!! 9secondflat has already been helped by competent proffesionals, not a gibberish drooling mental patient!!!![]()
Even with all your screw turns, I'm going to trailer you with every move you don't sea the tide change.
Idle = uses the main.
Main = uses the low.
No idle/top end nose dives = The low is gone.
No main/low end will not start, to more, the bike sort of, 'catch starts' when your ratio builds enough to make the fuel fire, THEN CATCHES then STOPS = Clogged jets to narrow hole openings, i.e., jet holes or low speed screw hole opening.
Introduce the accelerator pump = The Whoopie Cushion:
We are now in test ride the WOT/load me mode. I want a brisk accel away. DO I:
1. Nose dive ~ Then accel away? I am too lean at the accel plunge.
2. Stumble away ~ Then, I am too rich.
3. I am one or the other or 3rd move is the charm ~ I crisp away = No dive, no stumble, nothing but hard low end wheel chirping grunt is the fart noise at the back wheel is to accel away is the accel crisp or WOT?!
:2thumbs: = Trailer tuning says, you are still up for grabs = Come get your trophy tune. Get that theory or keep looking at your porcelain tip is the tip.
