I'd agree with that -- You can easily adjust the tension by adding shims.Lots of Forum Members sear by the Bandit clutch. Great set of springs too!!
He needs to open the primary -- If the clutch hub nut is loose and you have to do repeated adjustments you can easily trash the throw out bearing.Thanks you all. Jersey Mike, I'm only asking for a big dog owner who's asking for a performance clutch kit. He says it "gave out" after a few clutch adjustments.
Just call Bandit Machine Works in Lancaster PA -- tell them what you need and they can hook you up. Not like you can order it from anywhere else anyway.Does anyone have the part number for the bandit pack. At MBBW something has happened in my primary. In neutral when I pull the clutch it's make a roaring sound, when in gear and clutch pulled nothing but when riding in gear clutch not pulled the roaring is back and the primary is super hot...
