Is your bike still stock?
Yes I jump starter over with jump wire is that say bad starter relay?Is your bike still stock?
This verifiies the starter is good.I was able to jump the starter off with a jumper wire going to the 12 volt battery so is that telling me that the starter relay is bad
I didn't get that far I just bump it just to see if the starter would go I'll try to see if it will start tomorrow appreciate your feedback brotherWhen you jump the wire, remote jumper cables, WATTever you use, does the engine start up, yes or no?
Say yes it does. Then run a starter button off the starter motor.
Say it does not start, compression release solenoids are out of the loop doing this. Then the start button also triggers the start solenoids I would assume. Fuck that idea then.
I agree with Mike. Power is not making it to the solenoid from the switch. Faulty handlebar pcb probably the culprit.This verifiies the starter is good.
You need to check the handlebar switches next
If your bike was on and ready to go, when you jumped the starter did it start or not. If it didn't start handlebar switxhes are really the next step,.
Hey thanks for video that's going to help a lot
Hey y'all I thank it's the board in control switch thank ever one of u for your response I'll dance at y'all next w weddingHey y'all 04 Big dog chopper try to start the other day it turned over a couple times and then wouldn't do anything and it still won't push the start button and nothing I've had the battery check it's good I took the starter off had it checked it's good anybody got any similar problems information thanks
