Start Button Circuit Board
82ndAirborne
I'm changing out the (Start- On/Off-Turn Signal) Button Circuit Boards on both sides. The previous owner soldered one of the wires directly to the board so I need to replace it. The new wire came with the new board so no problem there. However, I'm having trouble removing the old wire where there is an attached fuse that inserts into a hole in the throttle assembly. It looks like I should just pull upwards on the wire and the fuse end will come out. It seems pretty tight so I want to be careful not to break it off. Is there a set screw holding the fuse? I've attached a few photos. Appreciate any help guys.
mleach72
That wire is your front brake sensor. There is a very small set screw that holds it in place. It is a .050" size.
