WTB EHC for 2004 Mastiff
local dealer is out of stock. want the newer EHC that replaced what used to come in the 04's. believe what's in the 2005+ models.
The replacement/upgraded EHC for your 04 is not the same as whats in newer models.
Dakotabos did a whole thread on it and you can find it on here somewhere and see what the new one looks like. It's still has only one port plug (it has a daughterboard on it) with the newer models have two plugs.
Agentbman
For that kind of money it should be the newer one!
I bought one of the older ones and the part was @ $240. Sounds like the newer one with adapter to fit 04's. You could do it yourself and save some $$, its not hard, but you need to have a little electrical know how.
:up:
got the bike back from the Strokers and the EHC checked out fine and was actually not the issue. was a bad starter and short in wiring for PCB causing the bike to either not start or incrementally die. still cost a good amount of $$ to fix.
so i wont need an EHC at this time.
