I found the thread by searching for " 02 starter relay"Yes your bike is ready for them. The two plugs marked are under your tank. Remember you need an 02 starter relay to use them. Many threads here on it. I think LDO did a How To on putting them in his 03 also. Been a lot of years ago since I had my 03 but I think I posted a copy of the service bulletin that tells you to use the 02 starter relay. You'll have to search it.
:2thumbs:
These two new relays that fit my 03 came up on Fleebay so i thought i would get a spare.Perfect, either will work
4120 was replaced by 4121. :2thumbs:
Dangit!These two new relays that fit my 03 came up on Fleebay so i thought i would get a spare.
Well two...
If you or someone needs one let me know?Dangit!
So you're the one! I was trying to pick those up myself!:lol:
Oh well, glad someone on here won them...![]()
Your speaking about the voltage spike coming from the solenoid when the starter is released. If I hook it to that terminal I will use a 1000 PIV 2.5A Diode in series to block that spike.Very True! But the surge might be a little hard on the comp. release solenoids, but it'll work. :2thumbs:
