Wire Plus
BADOG
I'm having the wire plus installed on my bike.
Spoke to the tech this morning and he's having trouble getting the air suspension to work. On the EHC it worked with the high and low beam switch.
Any thoughts?:(
Moespeeds
Call Jake or WP about this, I don't think you're the first guy with this issue. Why can't he just run it through a seperate switch under the seat or through a side cover?
jkd740
You're going to have to set it up on a separate switch as Moespeeds suggested. That's the only way. Easy to add and use when in the location of your choice.
