For not being an electrician the wire-plus was easy with Jake's directions. Thanks Jake. Everything worked except when I tried to start bike it ran real rough and died, and oil came out of the crank case vent, which is a 12" long hose w/little filter routed to the bottom of bike. When I looked in oil tank-only half full. The bike has set all winter, should I drain oil or try to start as is? HELP!
