well i got the bike to fire now. There is no 12volts to the igniton module on the red wire from the ehc. if i jump power to the red wire the thunder heart module will light up and it flashed while cranking, the bike will run until i kill power to the red wire. i wonder if i can wire the pwr wire with a switch or relay to 12volts. all other functions seem to work, blinkers,highlow beam, crank etc.... Will the ground on the ign switch carry enough current to ground a pwr relay? id like to save the expense of the wire plus kit for now i have a few other issues, can't seem to get the clutch adjusted right and the oring on one of the clutch forks rolled out. the wiring diagram i have seen on the wp374 seem to have a different number of plugs or wires to the ign module than my bike.
