N NYchopper Member Aug 5, 2008 #1 Not worried about the mounting bracket, just wondering if they will bolt up to the heads OK ? Thanks.
pig pen Well-Known Member Aug 5, 2008 #2 I think the trouble you may have would be most 117 are right side drive. They are most likely going to hang way out . Also I'm not sure they will even fit your cyclinders.
narow37 Angry Southern White Man Aug 6, 2008 #3 yes they will fit the heads but as pig pen said if you are trying to use stock pipes from a 117 they will most likely be for a RSD.
