M mptexas Member Oct 12, 2014 #1 I need to replace my outer primary gasket so i order one from WildsteelWorx. It is square where mine is round, do you all know if that will work?
KaptinAmerika Guru Oct 12, 2014 #2 Square gasket replaced the round gasket in the later years because it seals better.
Mickeetwo Guru Oct 12, 2014 #3 KaptinAmerika said: Square gasket replaced the round gasket in the later years because it seals better. Click to expand... Mine had the round also and replaced it with the square gasket
