TO tight of adjustmemt will snap them. 05chop
I agree 100%. If your adjustment is off, you will brake belts more often. I have never seen a belt brake on a BDM. Ironhorse.. yes, H-D.. yes, Bigdog and other brands.. no. If you get a stone or something in it, yes it can take the life out of it. I would keep the belt. If you are worried, after you do some motor mods just put a new belt on it. Gates/BDL makes the belts for the bigdogs. Belts have come a long way from what they used to be. Much smaller, much tighter and much stronger. Said to last close to 100k miles if adjusted properly. Chain is nice for a drag bike, dirt bike or sport bike, but not your nice $30k bike.
Keep in mind, if you do put a chain on...you will probably need to put some chain guides on as well around your swingarm/pivot area. Otherwise, you will end up having major problems. Such as the chain cutting threw your swingarm
