Yea I have a front and rear to go over the winter as Ill need new rubber. I agree I change them when I put on tires and every time they look pretty terrible. Seems excessive, but they are not that expensive.I am gonna check that out Eric, I still have to change the front, I got the berings here but I was gonna wait until I replace my front tire!
I also want the press to do some work on my truck
This is the one they have another wider one that's 20ton and it's a bit more money but also a bigger foot print in the shop. My space is limited so this might be it. Not wide enough to fit a tire, so you'll always have to remove the hubs which is fine since you should press them out anyways
http://m.harborfreight.com/12-ton-h...s1023_c4215b&utm_referrer=direct/not provided
