Whats the Difference??
awg
Ive seen quite a few 2004 BD Choppers. It seems to me that some of them look like they have a longer front end...some look like the frame is longer than others. Is there a difference or am I just seeing things? :)
snake1962
Are you sure you're not seeing a Ridgeback or K9? Don't think the K9 was made as far back as '04 but I could be wrong. Anyway the K9 and Ridgeback are longer than the Chopper. The K9 is like the bigger brother of the Chopper.
K9 started in '06
awg
No when I see the pictures on Ebay or Google of a Big Dog they just say Chopper. Yet some look different. I wasn't sure if BD made different models of chopper. I know they changed frames some where in 04 or 05. But to me they have a different look. Maybe I should wear my glasses next time.
Moespeeds
03/04 Choppers were mostly identical, with some small differences like controls, etc. 05 Chopper had a slightly different look with a redesigned fender, struts, bars, and went to right side drive. In 06 they made the K9 which was a few inches longer with more rake, and a redesigned gas tank. On ebay dealers will often list them all as choppers, since they don't know their ass from a hole in the ground.
DogsRUs
2004 Ridgeback
** SPECS PROVIDED BY BIG DOG MOTORCYCLES **
WARRANTY 2-YEAR Factory Warranty
Engine OHV 45 degree V-Twin
Displacement 107 cu. in. (1,750 cc)
Bore & Stroke 4" X 4.25"
Compression Ratio 9.6:1
Fuel System S&S Super G Carburetor
Fuel Capacity 4.25 gallons
Oil Capacity 2.75 quarts
Transmission Bake 6-speed
Primary Drive Chain
Final Drive Belt
Frame Stretch 8" downtube, 4" backbone, 2"rear axle
Frame Tubing 1.5" diameter
Frame Rake 37 degrees
Rear Suspension None - Rigid frame
Front Suspension 41mm Telescopic, 12" over
Seat Height 24.5"
Ground Clearance 4"
Wheel Base 82"
Total Length 107"
Front Brake PM 4-Piston Caliper
Rear Brake PM 4-Piston Caliper
Front Tire MH90 X 21
Rear Tire R250/40 X 21
Tire Pressure Front: 40 psi/Rear: 42 psi
Ignition Electronic
2004 Chopper
ENGINE:
Engine Type V Twin
Cylinders 2
Engine Stroke 4-Stroke
Cooling Air
Valve Configuration OHV - Pushrod
Starter Electric
Fuel Type Gas
TRANSMISSION:
Transmission Type Manual
Number Of Speeds 6
Primary Drive (Rear Wheel) Belt
WHEELS & TIRES:
Front Tire (Full Spec) MH90-21
Rear Tire (Full Spec) 250/40 R18
BRAKES:
Front Brake Type Disc
Rear Brake Type Disc
TECHNICAL SPECIFICATIONS:
Wheelbase (in/mm) 77.5 / 1968.5
Fuel Capacity (gal/l) 3.8 / 14.4
narow37
Angry Southern White Man
dont forget that the chopper had 3 different frames. daytec, rolling thunder, and BDM. you maybe seeing slight differences there. but they are still basically the same geometry.
