Are there any numbers i can look for to see if it has been changed.S&S 107 , if it is still factory you should be building around 105-108 HP. I talked to S&S last yr. the 107 made on average hp= cu.in.
Only if you tear the motor apart and see if it was recammed, or use your X-ray glassesAre there any numbers i can look for to see if it has been changed.
Thanks John....Thats the answer i was looking for.Call S&S with the engine #(front side of case by front lifter block), and they can tell you what you wan to know.
John
YEP.....Johns right.................Ray is right also............117 was a optional engine also...........Call S&S with the engine #(front side of case by front lifter block), and they can tell you what you wan to know.
John
