What size is my S&S
2004Chopperdt
Just bought a 2004 chopper dt that has been customized.
trying to find out what engine i have.
I believe i seen where it said ( Super Side Winder ) on the left hand side just below the cylinder.
Any feed back is welcome.
liferider
Looking forward to retirement
S&S 107 , if it is still factory you should be building around 105-108 HP. I talked to S&S last yr. the 107 made on average hp= cu.in.
FrankBDPS
S&S has some how to vids on utube that are very good.I watched one the other day on engine size.As far as the cam goes I have been told you would need to remove it to see exactly what it is.Good luck!
john sachs
Call S&S with the engine #(front side of case by front lifter block), and they can tell you what you wan to know.
John
04 was about the only year that we had an engine option. You could get a 117 that year
