What is the stock cam for an '05/117?
BadBrad
2005 Pitbull
Hey pound,
I pulled the cam out and was curious what size it was. The numbers on the cam are: 30-4000 UL9 175-05
Then in smaller numbers is: 3001GR
I'm familiar with cams being listed by 3 numbers, e.g. 600. That's what I'm going back in with.
Any idea what size this is?:confused:
BadBrad
2005 Pitbull
It would be a good idea to check your valve springs too.
Thanks PP. I have the red striped valve springs. I think RW said those were good enough for a 600 but I'll have the shop check'em out too. Especially the one that had the bolt lodged beside it. I have the rocker box lids off both sides so I'll take a look and make sure the springs on the forward cylinder are red striped too.
Thanks again.:cheers:
BadBrad
2005 Pitbull
I've read where many members have gone to the .600 cam. Could you tell a noticable difference from the stock cam and did you have to re-jet your carb? If so, what jets did you end up changing and what size did you go to and from? :D
R
Ridgeback Boy
Guest
I thought I read sometime back that the stock cam was like a 529?
It made a noticable difference but I also swapped out the carb for a G.
Think I am running a 78 and 31 jetting....it has been a while.
V
05 and maybe some 06 had a .569 Comp cam. The S&S cam in them now should be a .546. If you have the single wound bee hive spring its rated at .585
BadBrad
2005 Pitbull
I saw some Comp cams in a J&P book and the numbers were similar, so I feel sure you're right on that. Do the red stripes on the springs indicate anything in particular? I took for granted that it meant they were rated for a larger cam. Looks like assuming has screwed me again. :job: Damn! :bang::bang: I'm wearing the threads out on the bolts from pulling that head. That is the only way to change the springs, right? :confused: The cam is in, the engine is all back together other than putting the pipes back on. WTF. :rant: I'll do whatever I need to do before I turn it over.
