Weird Smell & Condensation?
Still working on it. I can't seem to get the throttle lag out of it. The bike itself is running a thousand times better now, but if I grab quite a bit of throttle it coughs at the carb and then blasts off... :bang:
Check your accelerator pump. It's supposed to prevent this. It should be about two turns out from seated on the pump arm. Adjust till you eliminate that lag.
