vibration noise
Kellen85
just purchased my 03 pitbull, has 6500 miles on it. anyway when the motor revs down it sounds lke somethings vbrating bad such as cranks. also doea while riding after pulling clutch in. any help?
Banned
lose nut behind the bars............:roll: just had to got there,,, we might need alittle more info..
Kellen85
while riding last night i noticed this noise after engageing clutch. it almost sounds like low fluid levels in tranny or case. i checked oil it seems to be ok. didnt check anything else. while just idleing and rev the motor once almost reved down the noise comes back. kinda sounds like the tranny pully could be loose also
NascarNutCase
If were my bike, I'd do some inspection. Pull the primary drive inpsection cover off and have a look, if nothing, I'd pull the whole primary drive cover off and check out from the compensator shaft all the way back to the clutch for irregularities.
It doesn't sound like the same problem to me, but when I bought my bike the previous owner left the spacer out for the compensator shaft and the front drive sprocket was way too loose. The primary chain was slapping against the cover.
