LA_Dog
Go Fast, Go Faster
Hello all and Happy New Year. Quick question hoping someone can give me a solid answer with reasoning behind it-
My motor is a 2001 TP 107, with TP case, TP jugs, Edelbrock heads and SS rocker boxes / SS rocker covers. Has a Jims breather gear. Rockers have umbrella valves. The entire motor in regards to case bolt pattern and camchest offset is patterned exactly after S&S V series motors. Same engine gasket set etc etc.
Up until I tore the motor apart for a rebuild, it has been breathing both from the crankcase and from the heads.
> crankcase vents to below motor using braided line- no checkvalves or anything.
> front head vents to rear head banjo bolt via crossover line, rear head banjo bolt vents to below motor with braided line. no checkvalves or anything.
Should I be using both the crank and head breathers? Should I block the head breathers and only use the crank breather? Or vice versa?
I'm not able to find a solid answer in ref to this type of Evo motor- so if anyone knows I'd love to get the scoop. I'd also like to understand the logic / reason for the answer.
