turns over but wont start...
southwindcycles
i have a a k9 with a 117
has fuel to carb-s&s shorty,
has spark to plugs, but weak-orange spark.
tested coil 18 ohm between plug posts, 3.4 between each side/12v post.
battery 12.8v
was running last week, tried to start this week, just turns over, no fire...
tried disconnecting 12v at coil and running jumper from battery...same/same
need help please
Coolbreezin
battery 12.8v
need help please
I have the same starting problem as stated above. However, I have a 05, no EFI. I removed the air cleaner to check to see if gas would squirt, but nothing. Any advice?
Coolbreezin
I called BDM Tampa just now. He said the jets are clogged from sitting 3 weeks. Sounds odd to me but ill clean them. Side note, i dont have a fuel pump. WOOHOO! One less thing to break.
francoblay1
The Spaniard
If this really was the problem, if I was you, I would clean the entire Carb real good and then install a fuel filter (Pingle) on the fuel line... also, check your petcock mesh for crap in there... your tank linen might be pealing.
Keep us posted.
southwindcycles
resolved....
Hey guys, thanks for the help, very appreciate it...
i tested evrything, all tested good....
put new plugs in...same problem...
got frustrated:bang::bang::bang:...hit the 'run' button a bunch of times...like 20...
hit the starter switch..started...let it run a good half hour to warm up...in Minnesota-still snow on the ground...
Hit 'run/kill' switch on handle bars...nothing-kept running...
hit it a few more times...engine finally shut down...
wouldn't start until i hit the run button a few times...
problem solved....run button shorting out...
:cheers::cheers::cheers:
francoblay1
The Spaniard
:2thumbs: One more problem solved! :cheers:
DIELECTRIC GREASE ON ALL CONNECTIONS!!!!!!!!! :2thumbs:
BadDawg Bill
Keep us posted.
2X If it were the run button you wouldn't get spark....
Coolbreezin
I found the steps to R&R the tank. Im going to clean the tank and carb, and while I have the tank off Im going to bypass the Run/Off button.
FrankBDPS
I was just wondering why you would try to by pass the switch when maybe there is just something wrong inside the switch or a bad connection or broken wire? My bike is older than yours and old school wired. I am not all that familiar with the ehc on you're bike so maybe you are going the right route. Good luck. Hope you get it running right.
Coolbreezin
My Start button died a couple years ago, so i bought a slam button from Curtis. I always forget to press the Run button. I ran into a small problem with the directions given me.
Anyway, i cleaned the carb, all jets and the tank. I found the problem was a bunch of white powdery gunk in the diaphragm at the bottom of the bowl. Extra cleaned everything inside the carb and she fired right up.
francoblay1
The Spaniard
:2thumbs: :cheers:
