turn key on and nothing
shortfuse
turn key on and nothing, no light, LED's work, ignition problem? Checked connections on cables....thoughts? Battery checks out
Ray
I had an issue a while back, someone told me to after making the battery was good and connections were good , to turn key on and start wiggling, slightly shacking the wires to find my issue. about 15 minutes into it , fixing to throw my hands up in frustration, shock a wire and wah-la found it , re soldered connection. I would also check the switch in all this too. Just thinking out loud at 3 in the morning.
Ray
shortfuse
ODD, grabbed a different battery and put it in, same problem. Took that one out and put my old one back in and boom it works! Must have been a connection somewhere but double and triple checked! Thanks for input!
liferider
Looking forward to retirement
Check the EHC ground wire. That was my problem yesterday when mine died. Took me 30 min. but I found the culpret!
