Trouble finding neutral
burnitdown
Bike shifts up and down through gears fine, but it's unable to return to neutral without shutting it off. Any advice?
Also, where can I buy gaskets? I have a 2003 big dog chopper
thanks in advance
Liam
Brew
Sounds like you may need to adjust your clutch. Can you be a little more specific when you say gaskets? Head gaskets? Primary cover gasket? By the way welcome from Washington State, hope you enjoy the site...:cheers:
PHATASS
I agree with Brew...adjust the clutch. Also what Trans Fluid are you using? I was running REDLINE and could never get it into neutral. Switched to Spectro 75W-140 and haven't had a problem since.
Nukeranger
Nukeranger
:DI switched to Spectro 75W-140 HEAVY DUTY PLATINUM 6-SPEED TRANSMISSION OIL and finding neutral is easy and consistent now.:D
