ewincell147
Anyone had any problems with a baker 6speed left side drive?
Most likely the belt slipping.If its not a bent shift fork then it sounds like ur shift linkage is out of adjustment causing it not to go into gears properly....and if thats not it then check ur belt tightness, might be to loose.... it maybe jumping a tooth when u step on the throttle little hard making it seem like the transmission
Hi E , How are you making out with your trans ? Any progress?Anyone had any problems with a baker 6speed left side drive?
Great news ! Thanks for the updateTrans is all good. Found clutch was put together wrong. Should work now. Will be on the road next week to test.
