Dynomike299
I had a leak behind the primary at the transmission, it was loosing trans fluid, Well dissembled the primary found the clutch basket was broken also, that's another story, Removes the back primary cover to see the main seal wasn't leaking it is a black rubber coated plug about 1 1/2 in diameter has a shaft poking out of it thus leaking trans fluid there, I'm mechanical inclined so this doesn't look good to me, a little incite to this issue would be great. I think its a thrust issue somewhere...... Here is a pic
