Trans leaking through primary?
drummin777
I started my winter teardown to repair a few things, replace all fluids and most bearings, and to fix some cosmetics. after pulling the outer primary, chain, clutch baskets, etc., it seems I have transmission fluid leaking from around the shaft and into my primary. How big of a deal is this? I planned on pulling the inner primary anyways, Im jsut wondering if there is anything I should know or lookout for. Thanks.:cheers:
There is a seal there. Have to get a new one and take care of it.
Dont want to run the trans dry... bad things will happen.
lee
I had the same thing when I removed my clutch - it takes the pressure off the seal, or so I thought. I thought it was normal with the clutch removed.
RCAdd1ct
JAFO
Check the input shaft bearing to the trans when you pull the primary.
Since the outer shafts are not supported the extra torque these motors make are hell on shaft bearings.
At least the ones I see at the HD shop I visit.
twowheel99
Also after you replace the seals make sure you use a protective collar over the shaft to keep from damaging the new seals.....
2
bigdogtech01
It is normal to have the transmission oil leak out when you remove your clutch assembly. This is because the level of fluid in the transmission is higher than the bottom of the main bearing. The inner hub of your clutch goes inside the left side transmission seal. This seals the primary oil from the transmission and the transmission oil from the primary.
-Make sure you check the bearings on the mainshaft while you have it all apart. Grab hold of the mainshaft with both your hands, try moving it up and down, if it moves at all, you need a transmission rebuild with new bearings, clips, and seals.
-Also, before you install your clutch and primary chain assy. make sure you remove your left side seal and install a new one. Remove the small o-ring that is on the mainshaft(if it is still there) and throw it in the garbage, DO NOT replace the O-Ring!!! Bigdog no longer uses it.
-Also, check to make sure there is a spacer between the end of the clutch hub and the Mainshaft left case bearing. It should have one there and it will be chrome in color, not black, if it looks damaged, replace it, it retails for less than $3.
-Make sure you top off the transmission fluid after all this, if you have not already drained it all.
Que
Bought a Bandit clutch and during assembly I noticed that the mainshaft moved a slight bit. I looked on here and noticed you guys said this was a sign of a failing bearing in the trans. Why is this never ending? Bike was bought with 20,000 miles on it, and it must have been HARD MILES. The oem clutch had one bad kevlar disc about the middle of the pack. Noticed not much oil came out when I removed the cover. Have all records from dealer and one thing they recommended to the previous owner was to inspect the primary. Now I guess it's to the transmission.
don't get too upset. if you look a little deeper into some of the posts about this situation, you will find that when the clutch is pulled for replacement, that there is some leakage around the trans shaft. this apparently is a fairly common thing (it usually starts when the clutch is removed), it does not mean that the bike was mistreated. i am not saying that there is not a problem, i am saying that there may not be as bad a situation as you think there is. good luck.
Claymation
Yes at like 6k miles my tranny bearings were bad. I was sucking primary fluid into the tranny and leaking out tranny vent. Im not Bakers biggest fan. Haaha we should have a pole.
