V
Have a slight wooble in the ring gear/clutch pack. Pulled the primary open because I was having difficulty adjusting the clutch. When I first got the 08 the clutch hub nut was loose so I headed staight for this to find that if I rotated the clutch pack in neutral the the chain would rise and fall and you could see the hub move slightly (very slightly ) from side to side as if the input shaft was bent.
Now another member (Double D) just posted the same thing and he ended up having a warp in the carrier i beleive
I got the stuff apart and every thing looks good to the eye so my question would be is what is the best way to check for trueness of the transmission input shaft ?
I don't have a indicator setup but I have done some simple thigs and it appears straight. Double D had the same problem and did some excellent vids on his problem.
Any Ideas? H E L P
V
Any Ideas? H E L P
V
