Racer
Tranny losing fluid into primary
OK, so I went to change my transmission fluid and primary fluid today. First I went to drain transmission fluid, very little came out. Then I went to drain primary and got about 51 oz. out. From what I have read on the forum I am quessing I have a bad seal? Has anyone changed this seal/o-ring? If so, do you have any pics.? Is the seal located behind clutch basket? Will I need a puller of any sort? Any help would be appreciated.
