Tranny leak
Cynbahd
I am seeing a small amount of tranny fluid after a long ride in and around the drain plug area. not sure if it is coming from the plug or the gasket. Anyine experienced this?
Cynbahd
Took the pulley cover off and it seems the leak is coming from behind the belt pullley. I saw a thread that described a similar issue and the possibility that the sprocket nut may have loossened. Can anyone tell me the size of nut (keep it clean) and if all I need to do is re-torque it down.
Would an overfill of say 22oz vs. 20 oz cause this to happen. Thx for the help.
Cynbahd
Thought I would give you all an update. Pulled the sprocket off to get to the spacer. The small o-ring which sits behind the spacer had a rip causing the Tranny fluid to seep out. Also, replaced the clutch pusrod as it was pretty scored up.
