Show good lookin bike.Now on your tire pressure!First off i know you are wanting to have a softer ride and i think lowering the pressure is the wrong way to go 2-5psi ok.30psi at 70mph dont you think you will build up alot of heat inside the tire?10PSI is a big jump. 05chopCool, thanks. I am running 30 now as weel. After putting the dyna beads in I was running 40 but it was way to rough. 30 should be better. I tend to "rotate" my back tire as well but need to not do that. They are too expensive to replace that often.
Rumor has it... Jake's dyna beads will get rid of that shake.I had mine at 20 for a short test run wish I would have had a pump with! Now I run 27 with a little shake at 120mph but that dosnt happen often
I had the same thing at 120 before the beads - just about got it to 120 last saturday with the beads with no shake - not sure if I was going as fast as I did before but couldn't have been far awayRumor has it... Jake's dyna beads will get rid of that shake.
I was told the shake was caused from growth and the tire could pull the bead open enough to leakRumor has it... Jake's dyna beads will get rid of that shake.
