Thunderheart ignition module
GiantViking
So i dropped the Wrench i was using to swap the battery out and it landed on and arced across the positive and the outside of the module case, Is it fried? im not getting any lights from the module when turned on and no lights on crank. im pretty sure i fried but if anyone could help it be much appreciated
Jersey Big Mike
100K mile club
Check your fuses and/or circuit breaker.
Disconnect battery as well and reconnect.
Since that's the ignition module only if I am correct, it should not effect the lights.
GiantViking
So That worked, checked the Circuit breaker and it was good, I disconnected and removed the battery, left everything disconnected for 24hr, just got it all put back together and it fired right up, Thanks for the help Gentlemen!
