getting close got her together but front cylinder was cutting in and out...i think ive narrowed it down to a bad front side coil....when it cuts out i can tap on coil and it picks back up...dont trust it enough to take her out and break her in...have done about 10 warm up cycles on her the last 4 have had no problems with missing out...if ive got to get new coil might as well use the one in the 5012 if it will work in the bigdog coil mount....did you use the coil in yours? direct bolt up?
