It has been backfiring alot and if i maintain speed it will cut out every now and then is that relatedCould be a burned out light. But that’s strange that the lights would burn out, I’m pretty sure the bulb completes the circuit. But if it’s running it sounds like it’s working fine without the lights. I think it would be hard to troubleshoot if it does go out down the road.
There is 2 connections on the module and only 1 is hooked up is the other supposed to beLook at the jst connectors between the cam sensor and ignition module to make sure everything is good with the connectors and the wires in the connectors ...also check for wear areas in the wiring between the two also....but if my guess is right your cam sensor is starting to fail and will cause the ignition module not to light up and also cause the misfire sometimes going down the road....
What is the nose cone coverIt should flash when running. If it's not flashing and running, I've seen people install cam sensor ignitions in the nose cone and leave the old thunderheart bolted in there but it's not being used.
Take off the nose cone cover and post a picture.
