throttle cable adj.
F
frogman
Guest
anyone know the proper way to adjust throttle cable on a o7 K-9??
kirk927
All I do is take the slack out of both cables, the push and pull side with the adjustment nuts. On the pull side, ( the throttle advance) I leave a small amount of slack in the cable to combat any bumps in the road and when moving slow through gravel and such. If you don't, the bumps will cause a completely tight adjustment to have you "floor" the gas and lurch possibly losing control of the dog. Hope this helps. Kirk
