The bike was running great up to this fluid change
jackiev
Guys - I changed my tranny fluids last week (using Red Line V-Twin synthetic) and since then, when starting out or leaving a stop lite, it is very difficult to shift from first to 2nd and from 2nd to 3rd. Doesn't seem to be an issue on the upper gears.
I only rode about 5 miles then came back and check the tranny fluid level. It was low, (did not screw the stem in, just dropped in as directed) but still showed on the stick. I don't think it should have caused this type of problem. I've since topped off the fluid with less than a 1/2 pint. Problem remains.
Seems to shift easier, if when stopping I shift down and stop on a slight engine compression. Not the way I usually stop. It then shift into first without the same, lockup type problem.
The bike was running great up to this fluid change.
Any thoughts would be appreciated.
Thanks
pknowles
RETIRED
Thanks
Go back to the original fluid.
